Mitglied 132515
Bringt nichts… Hier nochmal der ganze Bericht vom Boot bis zum öffnen der Konsole:
Bitte um schnelle Antwort.
Danke
Code:
11.09.11 14:48:13,000 bootlog: BOOT_TIME 1315745293 011.09.11 14:48:47,605 com.apple.kextd: Safe boot mode detected; invalidating system extensions caches.
11.09.11 14:48:47,641 com.apple.kextd: Cache file /System/Library/Caches/com.apple.kext.caches/Directories/System/Library/Extensions/KextIdentifiers.plist.gz is out of date; not using.
11.09.11 14:48:47,000 kernel: PMAP: PCID enabled
11.09.11 14:48:47,000 kernel: Darwin Kernel Version 11.1.0: Tue Jul 26 16:07:11 PDT 2011; root:xnu-1699.22.81~1/RELEASE_X86_64
11.09.11 14:48:47,000 kernel: vm_page_bootstrap: 561693 free pages and 486883 wired pages
11.09.11 14:48:47,000 kernel: kext submap [0xffffff7f8072e000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff800072e000]
11.09.11 14:48:47,000 kernel: zone leak detection enabled
11.09.11 14:48:47,000 kernel: standard timeslicing quantum is 10000 us
11.09.11 14:48:47,000 kernel: mig_table_max_displ = 72
11.09.11 14:48:47,000 kernel: TSC Deadline Timer supported and enabled
11.09.11 14:48:47,000 kernel: SAFE BOOT DETECTED - only valid OSBundleRequired kexts will be loaded.
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=4 LocalApicId=6 Enabled
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=5 LocalApicId=1 Enabled
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=6 LocalApicId=3 Enabled
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=7 LocalApicId=5 Enabled
11.09.11 14:48:47,000 kernel: AppleACPICPU: ProcessorId=8 LocalApicId=7 Enabled
11.09.11 14:48:47,000 kernel: calling mpo_policy_init for Sandbox
11.09.11 14:48:47,000 kernel: Security policy loaded: Seatbelt sandbox policy (Sandbox)
11.09.11 14:48:47,000 kernel: calling mpo_policy_init for Quarantine
11.09.11 14:48:47,000 kernel: Security policy loaded: Quarantine policy (Quarantine)
11.09.11 14:48:47,000 kernel: calling mpo_policy_init for TMSafetyNet
11.09.11 14:48:47,000 kernel: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
11.09.11 14:48:47,000 kernel: Copyright (c) 1982, 1986, 1989, 1991, 1993
11.09.11 14:48:47,000 kernel: The Regents of the University of California. All rights reserved.
11.09.11 14:48:47,000 kernel: MAC Framework successfully initialized
11.09.11 14:48:47,000 kernel: using 16384 buffer headers and 10240 cluster IO buffer headers
11.09.11 14:48:47,000 kernel: IOAPIC: Version 0x20 Vectors 64:87
11.09.11 14:48:47,000 kernel: ACPI: System State [S0 S3 S4 S5] (S3)
11.09.11 14:48:47,000 kernel: PFM64 0xf10000000, 0xf0000000
11.09.11 14:48:47,000 kernel: [ PCI configuration begin ]
11.09.11 14:48:47,000 kernel: console relocated to 0xf10010000
11.09.11 14:48:47,000 kernel: PCI configuration changed (bridge=16 device=4 cardbus=0)
11.09.11 14:48:47,000 kernel: [ PCI configuration end, bridges 12 devices 17 ]
11.09.11 14:48:47,000 kernel: AppleIntelCPUPowerManagement: Turbo Ratios 1234
11.09.11 14:48:47,000 kernel: AppleIntelCPUPowerManagement: (built 13:08:12 Jun 18 2011) initialization complete
11.09.11 14:48:47,000 kernel: mbinit: done [64 MB total pool size, (42/21) split]
11.09.11 14:48:47,000 kernel: Pthread support ABORTS when sync kernel primitives misused
11.09.11 14:48:47,000 kernel: com.apple.AppleFSCompressionTypeDataless kmod start
11.09.11 14:48:47,000 kernel: com.apple.AppleFSCompressionTypeZlib kmod start
11.09.11 14:48:47,000 kernel: com.apple.AppleFSCompressionTypeDataless load succeeded
11.09.11 14:48:47,000 kernel: com.apple.AppleFSCompressionTypeZlib load succeeded
11.09.11 14:48:47,000 kernel: AppleIntelCPUPowerManagementClient: ready
11.09.11 14:48:47,000 kernel: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID c82a14fffe8eb5de; max speed s800.
11.09.11 14:48:47,000 kernel: rooting via boot-uuid from /chosen: B81B619A-4CE0-395B-9A8C-0A1335AB387E
11.09.11 14:48:47,000 kernel: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
11.09.11 14:48:47,000 kernel: USBMSC Identifier (non-unique): 000000009833 0x5ac 0x8403 0x9833
11.09.11 14:48:47,000 kernel: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HDS722020ALA330 Media/IOGUIDPartitionScheme/Customer@2
11.09.11 14:48:47,000 kernel: BSD root: disk0s2, major 14, minor 1
11.09.11 14:48:47,000 kernel: Kernel is LP64
11.09.11 14:48:47,000 kernel: [IOBluetoothHCIController::setConfigState] calling registerService
11.09.11 14:48:47,000 kernel: IOThunderboltSwitch::i2cWriteDWord - status = 0x00000000
11.09.11 14:48:47,000 kernel: IOThunderboltSwitch::i2cWriteDWord - status = 0xe00002ed
11.09.11 14:48:14,636 com.apple.launchd: *** launchd[1] has started up. ***
11.09.11 14:48:51,000 kernel: BCM5701Enet: Ethernet address c8:2a:14:22:fb:9e
11.09.11 14:48:54,451 UserEventAgent: starting CaptiveNetworkSupport as SystemEventAgent built Jun 13 2011 17:29:21
11.09.11 14:48:54,466 UserEventAgent: CaptiveNetworkSupport:CaptiveSCCopyWiFiDevices:388 WiFi Device Name == NULL
11.09.11 14:48:54,779 UserEventAgent: CaptiveNetworkSupport:CaptiveSCCopyWiFiDevices:388 WiFi Device Name == NULL
11.09.11 14:48:54,802 configd: ioctl(SIOCGIFCAP) failed: Device not configured
11.09.11 14:48:55,061 UserEventAgent: CertsKeychainMonitor: configuring
11.09.11 14:48:55,494 configd: setting hostname to "Noel-Jeschkes-iMac.local"
11.09.11 14:48:55,496 configd: network configuration changed.
11.09.11 14:48:56,194 mDNSResponder: mDNSResponder mDNSResponder-320.5.1 (Aug 3 2011 19:57:38) starting OSXVers 11
11.09.11 14:48:56,435 com.apple.kextd: Cache file /System/Library/Caches/com.apple.kext.caches/Startup/IOKitPersonalities_x86_64.ioplist.gz is out of date; not using.
11.09.11 14:48:57,299 com.apple.SecurityServer: Session 100000 created
11.09.11 14:48:57,746 com.apple.SecurityServer: Entering service
11.09.11 14:48:58,033 systemkeychain: done file: /var/run/systemkeychaincheck.done
11.09.11 14:48:58,045 configd: network configuration changed.
11.09.11 14:48:58,046 configd: network configuration changed.
11.09.11 14:48:58,229 mDNSResponder: D2D_IPC: Loaded
11.09.11 14:48:58,229 mDNSResponder: D2DInitialize succeeded
11.09.11 14:48:59,000 kernel: nstat_lookup_entry failed: 2
11.09.11 14:48:59,563 UserEventAgent: ServermgrdRegistration cannot load config data
11.09.11 14:49:01,235 com.apple.kextd: Can't load AppleThunderboltEDMSink.kext - ineligible during safe boot.
11.09.11 14:49:01,236 com.apple.kextd: Load com.apple.driver.AppleThunderboltEDMSink failed; removing personalities from kernel.
11.09.11 14:49:01,350 com.apple.kextd: Can't load AppleSMBusPCI.kext - ineligible during safe boot.
11.09.11 14:49:01,351 com.apple.kextd: Load com.apple.driver.AppleSMBusPCI failed; removing personalities from kernel.
11.09.11 14:49:01,463 com.apple.kextd: Can't load AirPortAtheros40.kext - ineligible during safe boot.
11.09.11 14:49:01,464 com.apple.kextd: Load com.apple.driver.AirPort.Atheros40 failed; removing personalities from kernel.
11.09.11 14:49:01,479 com.apple.kextd: Can't load AppleHDAController.kext - ineligible during safe boot.
11.09.11 14:49:01,479 com.apple.kextd: Load com.apple.driver.AppleHDAController failed; removing personalities from kernel.
11.09.11 14:49:01,501 com.apple.kextd: Can't load AppleSMCLMU.kext - ineligible during safe boot.
11.09.11 14:49:01,502 com.apple.kextd: Load com.apple.driver.AppleSMCLMU failed; removing personalities from kernel.
11.09.11 14:49:01,514 com.apple.kextd: Can't load AudioIPCDriver.kext - ineligible during safe boot.
11.09.11 14:49:01,515 com.apple.kextd: Load com.apple.driver.AudioIPCDriver failed; removing personalities from kernel.
11.09.11 14:49:01,525 com.apple.kextd: Can't load IOFireWireIP.kext - ineligible during safe boot.
11.09.11 14:49:01,526 com.apple.kextd: Load com.apple.iokit.IOFireWireIP failed; removing personalities from kernel.
11.09.11 14:49:01,742 com.apple.kextd: Can't load ATIRadeonX3000.kext - ineligible during safe boot.
11.09.11 14:49:01,743 com.apple.kextd: Load com.apple.ATIRadeonX3000 failed; removing personalities from kernel.
11.09.11 14:49:02,016 com.apple.kextd: Can't load AppleIntelHDGraphics.kext - ineligible during safe boot.
11.09.11 14:49:02,018 com.apple.kextd: Load com.apple.driver.AppleIntelHDGraphics failed; removing personalities from kernel.
11.09.11 14:49:02,023 com.apple.kextd: Can't load ATIRadeonX3000.kext - ineligible during safe boot.
11.09.11 14:49:02,025 com.apple.kextd: Load com.apple.ATIRadeonX3000 failed; removing personalities from kernel.
11.09.11 14:49:02,000 kernel: Previous Shutdown Cause: 5
11.09.11 14:49:02,000 kernel: [ffffff800a7d4000][BNBMouseDevice::init][66] init is complete
11.09.11 14:49:02,000 kernel: [ffffff800a7d4000][BNBMouseDevice::handleStart][66] Done
11.09.11 14:49:02,000 kernel: [ffffff80093cdc00][AppleMultitouchHIDEventDriver::start] entered
11.09.11 14:49:02,209 com.apple.kextd: Can't load AppleTyMCEDriver.kext - ineligible during safe boot.
11.09.11 14:49:02,211 com.apple.kextd: Load com.apple.driver.AppleTyMCEDriver failed; removing personalities from kernel.
11.09.11 14:49:02,247 com.apple.kextd: Can't load IOAVBFamily.kext - ineligible during safe boot.
11.09.11 14:49:02,248 com.apple.kextd: Load com.apple.iokit.IOAVBFamily failed; removing personalities from kernel.
11.09.11 14:49:02,255 com.apple.kextd: Can't load AppleMCCSControl.kext - ineligible during safe boot.
11.09.11 14:49:02,257 com.apple.kextd: Load com.apple.driver.AppleMCCSControl failed; removing personalities from kernel.
11.09.11 14:49:02,260 com.apple.kextd: Can't load IOAVBFamily.kext - ineligible during safe boot.
11.09.11 14:49:02,262 com.apple.kextd: Load com.apple.iokit.IOAVBFamily failed; removing personalities from kernel.
11.09.11 14:49:02,278 com.apple.kextd: Can't load IOBluetoothSerialManager.kext - ineligible during safe boot.
11.09.11 14:49:02,280 com.apple.kextd: Load com.apple.iokit.IOBluetoothSerialManager failed; removing personalities from kernel.
11.09.11 14:49:02,301 com.apple.kextd: Can't load AppleUpstreamUserClient.kext - ineligible during safe boot.
11.09.11 14:49:02,304 com.apple.kextd: Load com.apple.driver.AppleUpstreamUserClient failed; removing personalities from kernel.
11.09.11 14:49:02,318 com.apple.kextd: Can't load IOSurface.kext - ineligible during safe boot.
11.09.11 14:49:02,320 com.apple.kextd: Load com.apple.iokit.IOSurface failed; removing personalities from kernel.
11.09.11 14:49:02,348 com.apple.kextd: Can't load IOUserEthernet.kext - ineligible during safe boot.
11.09.11 14:49:02,350 com.apple.kextd: Load com.apple.iokit.IOUserEthernet failed; removing personalities from kernel.
11.09.11 14:49:02,558 com.apple.kextd: Can't load ntfs.kext - ineligible during safe boot.
11.09.11 14:49:02,563 diskarbitrationd: unable to mount /dev/disk0s4 (status code 0x00000047).
11.09.11 14:49:03,025 com.apple.pfctl: No ALTQ support in kernel
11.09.11 14:49:03,025 com.apple.pfctl: ALTQ related functions disabled
11.09.11 14:49:03,000 kernel: [ffffff800a7a7200][AppleMultitouchDevice::start] entered
11.09.11 14:49:03,000 kernel: DSMOS has arrived
11.09.11 14:49:03,299 com.apple.ucupdate.plist: ucupdate: Checked 1 update, no match found.
11.09.11 14:49:04,000 kernel: macx_swapon SUCCESS
11.09.11 14:49:04,351 com.apple.locationd: ERROR,Time,337438144.351,Function,"_Apple80211* CLWifiService::createApple80211()",Apple80211GetIfListCopy failed, error -3903 (Unknown error: -3903)
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,1 locationd 0x00000001045983c3 locationd + 623555
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,2 locationd 0x0000000104598559 locationd + 623961
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,3 libdispatch.dylib 0x0000000106232afd _dispatch_barrier_sync_f_invoke + 33
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,4 locationd 0x00000001045987f0 locationd + 624624
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,5 locationd 0x0000000104598850 locationd + 624720
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,6 libsystem_c.dylib 0x0000000106318e06 pthread_once + 86
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,7 locationd 0x0000000104598887 locationd + 624775
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,8 locationd 0x000000010458d0b0 locationd + 577712
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,9 locationd 0x000000010458d243 locationd + 578115
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,10 libsystem_c.dylib 0x0000000106318e06 pthread_once + 86
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,11 locationd 0x000000010458d20d locationd + 578061
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,12 locationd 0x000000010454a242 locationd + 303682
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,13 locationd 0x000000010452b36b locationd + 177003
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,14 locationd 0x000000010452b720 locationd + 177952
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,15 locationd 0x000000010452beca locationd + 179914
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,16 locationd 0x000000010455d044 locationd + 380996
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,17 locationd 0x0000000104501ce4 locationd + 7396
11.09.11 14:49:04,352 com.apple.locationd: STACK,Time,337438144.351,18 ??? 0x0000000000000001 0x0 + 1
11.09.11 14:49:04,693 com.apple.SystemStarter: ls: /Applications/VirtualBox.app/Contents/MacOS/*-amd64: No such file or directory
11.09.11 14:49:05,000 kernel: nstat_lookup_entry failed: 2
11.09.11 14:49:05,480 com.apple.usbmuxd: usbmuxd-211 built on May 16 2011 at 00:14:56 on May 16 2011 at 00:14:55, running 64 bit
11.09.11 14:49:05,669 com.apple.SystemStarter: Loading VBoxDrv.kext
11.09.11 14:49:06,126 com.apple.kextd: Can't load /Library/Extensions/VBoxDrv.kext - ineligible during safe boot.
11.09.11 14:49:06,128 com.apple.SystemStarter: /Library/Extensions/VBoxDrv.kext failed to load - (libkern/kext) operation/kext not allowed at current boot level; check the system/kernel logs for errors or try kextutil(8).
11.09.11 14:49:06,129 com.apple.SystemStarter: Error: Failed to load /Library/Extensions/VBoxDrv.kext
11.09.11 14:49:06,129 com.apple.SystemStarter: Loading VBoxUSB.kext
11.09.11 14:49:06,423 com.apple.kextd: Can't load /Library/Extensions/VBoxUSB.kext - ineligible during safe boot.
11.09.11 14:49:06,443 com.apple.SystemStarter: /Library/Extensions/VBoxUSB.kext failed to load - (libkern/kext) operation/kext not allowed at current boot level; check the system/kernel logs for errors or try kextutil(8).
11.09.11 14:49:06,443 com.apple.SystemStarter: Error: Failed to load /Library/Extensions/VBoxUSB.kext
11.09.11 14:49:06,443 com.apple.SystemStarter: Loading VBoxNetFlt.kext
11.09.11 14:49:06,613 com.apple.kextd: Can't load /Library/Extensions/VBoxNetFlt.kext - ineligible during safe boot.
11.09.11 14:49:06,616 com.apple.SystemStarter: /Library/Extensions/VBoxNetFlt.kext failed to load - (libkern/kext) operation/kext not allowed at current boot level; check the system/kernel logs for errors or try kextutil(8).
11.09.11 14:49:06,616 com.apple.SystemStarter: Error: Failed to load /Library/Extensions/VBoxNetFlt.kext
11.09.11 14:49:06,617 com.apple.SystemStarter: Loading VBoxNetAdp.kext
11.09.11 14:49:06,751 com.apple.kextd: Can't load /Library/Extensions/VBoxNetAdp.kext - ineligible during safe boot.
11.09.11 14:49:06,754 com.apple.SystemStarter: /Library/Extensions/VBoxNetAdp.kext failed to load - (libkern/kext) operation/kext not allowed at current boot level; check the system/kernel logs for errors or try kextutil(8).
11.09.11 14:49:06,754 com.apple.SystemStarter: Error: Failed to load /Library/Extensions/VBoxNetAdp.kext
11.09.11 14:49:06,866 com.apple.SystemStarter: (kernel) Kext org.virtualbox.kext.VBoxNetAdp not found for unload request.
11.09.11 14:49:06,866 com.apple.SystemStarter: Failed to unload org.virtualbox.kext.VBoxNetAdp - (libkern/kext) not found.
11.09.11 14:49:06,929 com.apple.SystemStarter: (kernel) Kext org.virtualbox.kext.VBoxNetFlt not found for unload request.
11.09.11 14:49:06,929 com.apple.SystemStarter: Failed to unload org.virtualbox.kext.VBoxNetFlt - (libkern/kext) not found.
11.09.11 14:49:06,985 com.apple.SystemStarter: (kernel) Kext org.virtualbox.kext.VBoxUSB not found for unload request.
11.09.11 14:49:06,985 com.apple.SystemStarter: Failed to unload org.virtualbox.kext.VBoxUSB - (libkern/kext) not found.
11.09.11 14:49:07,000 kernel: Kext org.virtualbox.kext.VBoxNetAdp not found for unload request.
11.09.11 14:49:07,000 kernel: Kext org.virtualbox.kext.VBoxNetFlt not found for unload request.
11.09.11 14:49:07,000 kernel: Kext org.virtualbox.kext.VBoxUSB not found for unload request.
11.09.11 14:49:07,056 com.apple.SystemStarter: (kernel) Kext org.virtualbox.kext.VBoxDrv not found for unload request.
11.09.11 14:49:07,056 com.apple.SystemStarter: Failed to unload org.virtualbox.kext.VBoxDrv - (libkern/kext) not found.
11.09.11 14:49:07,056 com.apple.SystemStarter: -f VirtualBox
11.09.11 14:49:07,112 SystemStarter: VirtualBox Support and USB Drivers (92) did not complete successfully
11.09.11 14:49:07,742 mds: (Normal) FMW: FMW 0 0
11.09.11 14:49:08,000 kernel: Kext org.virtualbox.kext.VBoxDrv not found for unload request.
11.09.11 14:49:08,206 loginwindow: Login Window Application Started
11.09.11 14:49:11,254 SystemStarter: The following StartupItems failed to start properly:
11.09.11 14:49:11,254 SystemStarter: /Library/StartupItems/VirtualBox
11.09.11 14:49:11,254 SystemStarter: - execution of Startup script failed
11.09.11 14:49:13,599 rpcsvchost: sandbox_init: com.apple.msrpc.netlogon.sb succeeded
11.09.11 14:49:15,117 WindowServer: Unable to open IOHIDSystem (e00002bd)
11.09.11 14:49:15,530 loginwindow: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
11.09.11 14:49:16,000 kernel: virtual bool IOHIDEventSystemUserClient::initWithTask(task*, void*, UInt32): Client task not privileged to open IOHIDSystem for mapping memory (e00002c1)
11.09.11 14:49:16,759 com.apple.launchctl.LoginWindow: com.apple.findmymacmessenger: Already loaded
11.09.11 14:49:17,015 com.apple.SecurityServer: Session 100003 created
11.09.11 14:49:17,029 loginwindow: Login Window Started Security Agent
11.09.11 14:49:17,169 WindowServer: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
11.09.11 14:49:17,169 loginwindow: kCGErrorFailure: CGSPackagesGetWorkspaceType: couldn't get workspace type
11.09.11 14:49:17,169 loginwindow: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
11.09.11 14:49:17,387 SecurityAgent: Echo enabled
11.09.11 14:49:19,367 SecurityAgent: kCGErrorFailure: CGSPackagesGetWorkspaceType: couldn't get workspace type
11.09.11 14:49:19,367 SecurityAgent: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
11.09.11 14:49:21,987 warmd: [___bootcachectl_filter_out_sharedio_from_history_block_invoke_0:1679] Unable to open i386 shared cache: 2 No such file or directory
11.09.11 14:49:22,607 com.apple.kextd: Can't load ntfs.kext - ineligible during safe boot.
11.09.11 14:49:22,686 com.apple.kextd: Can't load ntfs.kext - ineligible during safe boot.
11.09.11 14:49:22,722 genatsdb: *GENATSDB* FontObjects generated = 334
11.09.11 14:49:23,704 SecurityAgent: User info context values set for Noel
11.09.11 14:49:27,684 loginwindow: Login Window - Returned from Security Agent
11.09.11 14:49:27,852 loginwindow: USER_PROCESS: 68 console
11.09.11 14:49:28,276 com.apple.launchd.peruser.501: (com.apple.quicklook.32bit) Unknown key for boolean: DisallowDataExecute
11.09.11 14:49:28,276 com.apple.launchd.peruser.501: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
11.09.11 14:49:28,568 UserEventAgent: servermgr_certs[10] -[CertsRequestHandler(HelperAdditions) identitiesFromKeychain:]: SecItemCopyMatching (err = -25300)
11.09.11 14:49:28,618 com.apple.UserEventAgent-System: SecItemCopyMatching: Das angegebene Objekt konnte nicht im Schlüsselbund gefunden werden.
11.09.11 14:49:28,624 UserEventAgent: servermgr_certs[10] -[CertsRequestHandler(HelperAdditions) identitiesFromKeychain:]: SecItemCopyMatching (err = -25300)
11.09.11 14:49:28,624 com.apple.UserEventAgent-System: SecItemCopyMatching: Das angegebene Objekt konnte nicht im Schlüsselbund gefunden werden.
11.09.11 14:49:28,625 UserEventAgent: CertsKeychainMonitor: ready to process keychain & timer events
11.09.11 14:49:28,796 UserEventAgent: CaptiveNetworkSupport:CNSServerRegisterUserAgent:187 new user agent port: 34831
11.09.11 14:49:28,981 mds: (Warning) Server: No stores registered for metascope "kMDQueryScopeComputerIndexed"
11.09.11 14:49:29,483 com.apple.locationd: ERROR,Time,337438169.483,Function,"_Apple80211* CLWifiService::createApple80211()",Apple80211GetIfListCopy failed, error -3903 (Unknown error: -3903)
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,1 locationd 0x0000000109a133c3 locationd + 623555
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,2 locationd 0x0000000109a13559 locationd + 623961
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,3 libdispatch.dylib 0x000000010b6bfafd _dispatch_barrier_sync_f_invoke + 33
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,4 locationd 0x0000000109a137f0 locationd + 624624
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,5 locationd 0x0000000109a13850 locationd + 624720
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,6 libsystem_c.dylib 0x000000010b7a7e06 pthread_once + 86
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,7 locationd 0x0000000109a13887 locationd + 624775
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,8 locationd 0x0000000109a080b0 locationd + 577712
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,9 locationd 0x0000000109a08243 locationd + 578115
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,10 libsystem_c.dylib 0x000000010b7a7e06 pthread_once + 86
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,11 locationd 0x0000000109a0820d locationd + 578061
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,12 locationd 0x00000001099c5242 locationd + 303682
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,13 locationd 0x00000001099a636b locationd + 177003
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,14 locationd 0x00000001099a6720 locationd + 177952
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,15 locationd 0x00000001099a6eca locationd + 179914
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,16 locationd 0x00000001099d8044 locationd + 380996
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,17 locationd 0x000000010997cce4 locationd + 7396
11.09.11 14:49:29,483 com.apple.locationd: STACK,Time,337438169.483,18 ??? 0x0000000000000001 0x0 + 1
11.09.11 14:49:34,130 _mdnsresponder: /usr/libexec/ntpd-wrapper: scutil key State:/Network/Global/DNS not present after 30 seconds
11.09.11 14:49:34,949 _mdnsresponder: Unable to resolve hostname(s)
11.09.11 14:49:35,550 ntpd: proto: precision = 1.000 usec
11.09.11 14:49:38,894 com.apple.loginwindow: Noel Jeschkes iMac
11.09.11 14:49:40,035 SystemUIServer: Could not load menu extra NSBundle </System/Library/CoreServices/Menu Extras/Volume.menu> (not yet loaded) for Class AppleVolumeExtra
11.09.11 14:49:47,375 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:47,376 com.apple.dock.extra: 2011-09-11 14:49:47.373 com.apple.dock.extra[198:1707] Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:47,376 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:47,377 com.apple.dock.extra: 2011-09-11 14:49:47.375 com.apple.dock.extra[198:1707] Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:47,377 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:47,378 com.apple.dock.extra: 2011-09-11 14:49:47.376 com.apple.dock.extra[198:1707] Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:47,379 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:47,379 com.apple.dock.extra: 2011-09-11 14:49:47.378 com.apple.dock.extra[198:1707] Could not connect the action buttonPressed: to target of class NSApplication
11.09.11 14:49:48,464 mds: (Warning) Server: No stores registered for metascope "kMDQueryScopeComputer"
11.09.11 14:49:48,584 mds: (Error) Server: Disabled store registered for scope "/Users/Noel"
11.09.11 14:49:48,584 mds: (Error) Server: Disabled store registered for scope "/Applications"
11.09.11 14:49:51,023 com.apple.coremedia.videodecoder: IOSurface couldn't open service: IOSurfaceRoo
Danke
