Es müßte da gewesen sein mit dem Ausschalten.
Möglicherweise noch 30 Secundfen früher, ich kann das ja nicht deuten.
Sollten frühere Logs benötigt werden, kann ich die noch reinstellen
02.06.11 22:28:29 com.apple.launchd[1] *** launchd[1] has started up. ***
02.06.11 22:28:48 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 5 seconds
02.06.11 22:28:50 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 4 seconds
02.06.11 22:28:54 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:29:04 com.apple.SystemStarter[33] Starting HP Trap Monitor
02.06.11 22:29:04 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:04.576 SierraSWoCTool[149:903] SierraSWoCTool: main, version 1.2.5, number of args = 1 ((null))
02.06.11 22:29:04 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:04.592 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:04 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:04.592 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (0)...
02.06.11 22:29:05 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:05.603 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:05 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:05.606 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (1)...
02.06.11 22:29:05 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:29:05 com.parallels.vm.prl_naptd[159] QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
02.06.11 22:29:05 com.parallels.vm.prl_naptd[159] QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
02.06.11 22:29:06 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:06.618 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:06 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:06.619 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (2)...
02.06.11 22:29:06 com.apple.launchd.peruser.501[175] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
02.06.11 22:29:07 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:07.630 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:07 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:07.631 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (3)...
02.06.11 22:29:08 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:08.642 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:08 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:08.642 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (4)...
02.06.11 22:29:09 com.apple.launchd.peruser.501[175] (com.apple.Kerberos.renew.plist[198]) Exited with exit code: 1
02.06.11 22:29:09 com.parallels.vm.prl_pcproxy[201] QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
02.06.11 22:29:09 com.parallels.vm.prl_pcproxy[201] QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
02.06.11 22:29:09 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:09.655 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:09 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:09.656 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (5)...
02.06.11 22:29:10 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:10.669 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:10 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:10.672 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (6)...
02.06.11 22:29:10 HPEventHandler[213] DebugAssert: Third Party Client: ((__null) != m_lock && 0 == (*__error())) Can't create semaphore lock [/Volumes/Development/Projects/HP/MacRubens_Branch/mac-aio/core/HPEventHandler/Sources/HPTMNotificationManager.cpp:59]
02.06.11 22:29:11 com.apple.WindowServer[134] Thu Jun 2 22:29:11 klaus-hubners-macbook-pro.local WindowServer[134] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
02.06.11 22:29:11 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:11.688 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:11 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:11.689 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (7)...
02.06.11 22:29:11 com.apple.launchd.peruser.501[175] (
[email protected][204]) Exited with exit code: 1
02.06.11 22:29:12 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:12.702 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:12 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:12.703 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (8)...
02.06.11 22:29:12 [0x0-0xe00e].com.skype.skype[215] WirelessAttach: IOServiceOpen error: e00002c7
02.06.11 22:29:13 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:13.725 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:13 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:13.730 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (9)...
02.06.11 22:29:14 [0x0-0xe00e].com.skype.skype[215] WirelessAttach: IOServiceOpen error: e00002c7
02.06.11 22:29:14 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:14.748 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:14 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:14.748 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (10)...
02.06.11 22:29:15 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:29:15 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:15.770 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:15 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:15.771 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (11)...
02.06.11 22:29:16 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:16.784 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:16 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:16.785 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (12)...
02.06.11 22:29:17 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:17.798 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:17 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:17.799 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (13)...
02.06.11 22:29:18 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:18.812 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:18 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:18.813 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (14)...
02.06.11 22:29:19 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:19.826 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:19 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:19.827 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (15)...
02.06.11 22:29:20 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:20.841 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:20 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:20.842 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (16)...
02.06.11 22:29:21 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:21.869 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:21 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:21.883 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (17)...
02.06.11 22:29:22 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:22.897 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:22 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:22.897 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (18)...
02.06.11 22:29:23 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:23.921 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:23 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:23.921 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (19)...
02.06.11 22:29:24 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:24.934 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:24 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:24.935 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (20)...
02.06.11 22:29:25 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:29:25 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:25.953 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:25 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:25.955 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (21)...
02.06.11 22:29:26 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:26.971 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:26 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:26.973 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (22)...
02.06.11 22:29:27 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:27.989 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:27 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:27.990 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (23)...
02.06.11 22:29:29 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:29.004 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:29 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:29.005 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (24)...
02.06.11 22:29:30 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:30.019 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:30 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:30.020 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (25)...
02.06.11 22:29:31 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:31.033 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:31 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:31.034 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (26)...
02.06.11 22:29:32 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:32.048 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:32 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:32.049 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (27)...
02.06.11 22:29:33 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:33.063 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:33 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:33.064 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (28)...
02.06.11 22:29:34 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:34.076 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:34 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:34.077 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (29)...
02.06.11 22:29:35 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:35.091 SierraSWoCTool[149:903] SierraSWoCTool: findDriver - getInterfaceWithName failed e00002bc
02.06.11 22:29:35 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:35.093 SierraSWoCTool[149:903] SierraSWoCTool: main - Waiting for driver (30)...
02.06.11 22:29:35 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:29:36 com.sierrawireless.SWoCTool[56] 2011-06-02 22:29:36.094 SierraSWoCTool[149:903] SierraSWoCTool: main - Exit, returning 0
02.06.11 22:29:45 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:29:55 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:30:05 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:30:15 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:30:25 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:30:35 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:30:45 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:30:55 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:31:05 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:31:15 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
02.06.11 22:31:25 com.apple.launchd[1] (com.apple.InternetSharing) Throttling respawn: Will start in 10 seconds
